aod trans mount?
Discussion in 'Technical' started by timsrick, Oct 8, 2008.
  1. timsrick
    timsrick Member
    woodville,ont.canada
    1977 maverick,77 comet
    i have a crossmember form 71gold,but what mounts are people using?:huh:
  2. Comet155
    Comet155 Member
    Do you mean the rubber unit between the cross-member and tranny?
    If that's the case, the stock c4 unit will interchange, if memory serves.
  3. Dave B
    I bought a poly one from NPD.
  4. 71gold
    we use the same one on...C4s...AODs and T-5s...:Handshake
  5. mean_maverick
    what he said... the new mount that was on my C4 bolted right to my T5, which was also used on an AOD at one point as well :rolleyes:
  6. Jamie Miles
    Alto, GA
    I've had a few
    I've also verified that the C4 mount will bolt onto a 5R55E 5 speed auto out of a Ranger and a SROD 4 speed. I'm sure it'll bolt on a C6, too.
  7. timsrick
    timsrick Member
    awesome thanks guys, tim
  8. rthomas771
    If it fits a C4 then it fits the Toploader also
  9. PaulS
    I would recommend against the hard poly mounts for the transmission. It needs to flex a bit to keep from breaking the extension housing. It does make a difference on how much torque your engine produces and whether or not your engine mounts break. If you break an engine mount and it torques over then that rear mount tries to hold the back of the case in place - SNAP! you need a new rear housing or a case in extreme conditions.
  10. timsrick
    timsrick Member
    i ended up with a new mount for a 93 towncar.fits and is inexpensive..
