Aod transmission???
Discussion in 'General Maverick/Comet' started by 1973Maverick357, Jul 23, 2009.
  1. 1973Maverick357
    Cookeville TN
    I hear many people talk about AOD transmissions i need help!! Is this what i need? If so how much is it worth??
    Heres the details.
    Has RF-E3SP-7006 labeled on the side of the transmission, and
    the #23 on the bell Housing. Was told that if it is 6" between the top bolts on bell housing that it is for a small block,
    and if there is 8" between the bolts that it is a for a big block. This one is 6".
  2. 1973Maverick357
    Cookeville TN
    WHeres Frank??
  3. Alan Duke
    Alan Duke Member
    Houston, TX
    1973 Maverick
    Frank can also get you the crossmember you will need if it is the correct tranny. Good deal too. PaulS can also help you.
  4. 1973Maverick357
    Cookeville TN
    Yeah i need Pauls or Frank or some expert!
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    got a pic of the other side? something seems wrong..... or i have an older version....
  6. 71gold
    I'm at the Roundup...:bananaman
    i need a closer pic. of this same side...
    Frank...:Handshake
  7. Alan Duke
    Alan Duke Member
    Houston, TX
    1973 Maverick
  8. Cleaver
    Cleaver Member
    MD
    Chel
    Is there a big block AOD version? I thought you had to mill the bell and weld on an adapter plate to adapt to a big block? Nevertheless - it looks like the one I swapped into my Fairlane. Should just be a 4 wire plug on the left side for the neutral safety and the back-up lights. I paid $60 for it at the Pull-a-Part in Winston-Salem. Took me about 45 minutes of steady work to drop it out from under a crown vic. I would pay $100 for a core already on the ground. It's worth more if you know the history and know for sure it shifts. My two cents.
    Cleaver
  9. 71gold
    that's what i can't see in this pic.
