Are 78 mustang 2 gears 3:40 good.
Discussion in 'Technical' started by Thomas, May 16, 2009.
  1. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    I found a 78 Mustang with axle code 7. having 3:40 gears non locking. Is this going to be good ?
    I have a 250 eng. automatic. 8 inch rear. 2:79 gears.
    I don't understand what the non locking means?
    I couldn't get to see the tag being that its sitting on the ground with a 1/2 a ton of car over it.
    The wreaker wanted $150.00 Can. for the the hole axle.
    Is this a good price to pay for the gears?
    thanks for the help.
  2. mean_maverick
    you can buy a new set of gears from Summit for $150. i think it's a bit high myself considering you just need the gears, and it's "non-locking" (which means it's an open carrier and ISNT a posi and/or traction-lok unit)
  3. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I have to agree..it does sound a bit expensive! But then they are getting tougher to find(here anyway) and it is a drop in unit so it is ready to go now... I would see if they can drop the price a little...it that the whole rear or just the centre section?
  4. Bryant
    150 isnt that bad of a price. sure a new gear set costs that much but you still have to pay to have it installed. you can put your third member back in to the m2 housing and sell if for a few bucks on craigs list.
  5. JHodges
    JHodges thumper
    Dora Alabama
    It seems like a decent deal. If you bought the gears by themselves thats $150+$50 for a basic rebuild kit and probaly $100 or so to set them up unless you have a friend who knows how
  6. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    They want to sell it as the whole rear. When you say it is a drop in unit. do you mean I just have to swap in the center section? I'm always learning more about this stuff, and I don't even know what the gears look like. but I figure if I have something here, now, that I can use, maybe I should pick it up.
  7. Grabber71
    Yup..if the Mustang has an 8" also...you can just pull the axles and then just exchange the centre sections...for a whole rear $150 is not out of line
  8. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    O-kay, I gess the 3:40 would be an upgrade from the stock gears. now I'll have to find $150 to pay the man.:hmmm: It may have to wait a little while.
    Thank you all for the help?
    How much more horsepower would I get out of it?
  9. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Well if it's an 8" rear... It would be at least as strong as stock, and there are people here who run lots of power through 8" rearends. Some people will tell you it's junk because it's not a 9", I but I don't recall reading a lot of posts about shattering ring gears here on the MMB.
    Now when I was on Camaro and S10 forums, it was different. I personally destroyed 4 GM 10-bolt rearends using the unholy brute force of a mostly stock 305. :rolleyes:
  10. Bryant
    you will get no horse power from the gear change. you get torque multiplecation from the ratio change. if you put it on a chassie dyno usually the hp drops when you goto a numaricly higher gear. thats been a way of cheating chassie dyno numbers.
  11. facelessnumber
    Memphis, TN
    '71 Grabber
    Ah, guess I misread the question. Right. Gear change doesn't give you horsepower, it gives you acceleration at the low end at the expense of top end speed.
  12. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Is there a real benifit to swaping the gears?
    Would I save money on gas?
    I see the 3:55 with the tlok are popular. Would the 3:40 be real different?
    Are the 3:55 with the tlok rare? to find on a Mustang 2?
    :hmmm::hmmm::hmmm::hmmm:
  13. facelessnumber
    Memphis, TN
    '71 Grabber
    You would be unlikely to tell much difference between 3.40 and 3.55. To me, yes there's a benefit! Your car will certainly "feel" faster and more powerful, because your engine will be revving higher at lower speeds. Your acceleration will improve. Track times will likely improve if you're into that sort of thing. Gas mileage will not improve though. And your potential top speed will decrease.
    I think Trac-lock 8" rears are not terribly uncommon in Pinto wagons and they can be found in a few Mustang II's. For me though, the MII's and Pinto wagons are what's getting hard to find.
