Are the rear spring bushings 2 piece or 1 piece?
Discussion in 'Technical' started by olerodder, Dec 30, 2012.
  1. olerodder
    olerodder Member
    NorCal
    I am in need of replacing the spring bushings and just wondered for those of you who have replaced them if they are 1 piece or 2 piece and where you can get them...............................Poly would be also be an option.
    Thanks
  2. car-nut
    car-nut Glenn
    conn.
    2 piece. I just removed mine last weekend.
  3. scooper77515
    The rear ones at the shackles are two pieces. One piece up front, pressed in.
    My front one is a solid aluminum piece that came with the Cal-trac setup. The rear ones I replaced with AutoKrafter's rubber replacements. I would assume Poly replacements would be easy to find. Should be the same as any early mustang.
    http://autokrafters.com/c-699-bushings.aspx
  4. rthomas771
  5. don graham
    got mine at NAPA.:)
  6. 71gold
    ...both...:yup:
  7. Acornridgeman
    Wisconsin
    Mustangs are a fatter bushing - they don't fit. The metal parts of the shakle are the same, but not the rubber.
  8. olerodder
    olerodder Member
    NorCal
    Thanks guys, I wasn't so much worried about the rear shackle bushings but more about the front spring eye bushing............on one side part of the rubber is mostly gone.......................
  9. scooper77515
    Ah! Thanks for clearing that up for me. I would have gotten mine from the local mustang house next time I needed a set. I know better now.
  10. Bryant
    i would get the dimension of the bushings you need and check with energy suspension. they do have bushings available by dimension. they list allot of them in their catalog.
