Ok, so I installed new A arms and forgot to instal the 90* grease fitting first!. Although, now that I am doing it via the wheel wells I notice that on each side the front one will not clear the body. So, Can I grease the A arms from just one side and avoid the squeaks! I see no way to get the front one in there. Thoughts ? Scott
Sounds like maybe the shaft isn't centered with the arm. It's not hard to get them arms in and out... if you have the right tools and time.
my thoughts also...the regular 90 degree fitting will not work...get the zerk fittings for the mustang...:Handshake ...
i solved this problem very easily. i bored a nice clean factory looking hole in the front of my shock towers. its so easy to grease the front fittings now.
