Arm Rest
Discussion in 'General Maverick/Comet' started by 55crownvic, Mar 8, 2015.
  1. 55crownvic
    55crownvic Member
    colorado springs
    So am I right to assume there are NO new arm rests available for a 70 Maverick? Havent seen any.
  2. bluezjeep
    bluezjeep Member
    Colorado
    1971 Maverick 302 C4
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    pretty sure that I've seen other Fords and Mustangs using the same ones too.
  4. CaptainComet
    There are two different sizes in the early style ... standard and Grabber. The Grabber ones are a bit longer and have a notch to use as a pull, making them side-specific. They use a longer base, too, and could be adapted to a standard door panel by opening up the rear mounting point. The doors have provisions for both. (but being a 70, check to be sure.... not sure if it may be a 71-72 feature)
    The one shown in the Melvins ad is the standard size. Those also were used in the back seat of some other models ... 70-71 Torino, for sure.
    I have some OK to good used standard ones here, depending on what color you want. Got some longer LTD pads too, in dark green (easy to dye black), same length as Grabber, but no notch.
  5. Craig Selvey
    Not just Grabbers got the longer arm rest. It was used on the deluxe interior....which ANY Maverick could have.
  6. rthomas771
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    Don't limit your search criteria. These shorty units probably got carried over from many older Fords too and I do know for fact that some of the old station wagons had them on all four doors.
    To be more specific.. I have several multi-model links saved for these standard interior style re-pops and they look to be identical to these Mav/Comet units. Many show being used on 71-73 Mustangs(and many other years if my old memory and google pics can be trusted), and 70/71 Torinos(of which I owned 3).
  8. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
