Arm rests
Discussion in 'Parts Interchange' started by Jamie Miles, Feb 14, 2006.
  1. Jamie Miles
    Alto, GA
    I've had a few
    Was at the junkyard today and was checking out an '85 Bronco they just hauled in. The rear arm rests look identical to 70-72 Maverick/Comet arm rests. Anyone know if they will the actually interchange?
  2. grbmaverickmo
    Aquashicola, PA
    I have bronco ones in my driver.
  3. Earl Branham
    Lugoff, SC
    Jamie; what color are they? I might be interested. I need black ones.
  4. Jamie Miles
    Alto, GA
    I've had a few
    They are black Earl. Looked to be in pretty good shape. I can go back and get them tomarrow and give them to you Saturday if you want them. Should be able to get them for under $10. You don't want them, I'll just put them in my car.
    Good to know there is a newer much more plentiful source to get them. Guess thats another part I will start snatching up every time I see them.
  5. Earl Branham
    Lugoff, SC
    Jamie; thanks. Are you coming down this way on Saturday? If so, let me know where to meet you. Thanks,
    Earl
  6. Jamie Miles
    Alto, GA
    I've had a few
    I believe we are going to work on the '77, but not positive on that. All I know is I gotta be at Terry's by 8 A.M. tomarrow morning. Not sure I if I will drive the Maverick or not, still haveing on and off wheel bearing problems. I need to get a new hub for the passenger side.
  7. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    They'll swap.......the bases are different
  8. Jamie Miles
    Alto, GA
    I've had a few
    Yep. I'll be snatching up every set I see from now on. ;)
  9. Jamie Miles
    Alto, GA
    I've had a few
    Finnally had time to get back up to Pull-A-Part this morning and get them. They were pretty nasty, but hot soapy water and some 409 fixed that. Whoever had that Bronco must have smoked. They have the same 1970 part number as the original Maverick arm rests. Got them for $3.50 a piece.
  10. hotrod-daddy
    hotrod-daddy Member
    Glad you got 'em befor someone else did....
  11. Jamie Miles
    Alto, GA
    I've had a few
    Ahh, would have just waited for the next Bronco to come through. Usually a couple of new ones a month.
