? auto 77mav shifter bars to trans help
Discussion in 'Technical' started by loopydog, Oct 25, 2002.
  1. loopydog
    loopydog Member
    ontario
    762d@774d
    i took them off and stupid me i cant remember what all gose back there. right at the tran bar that buts it in to drive and theres a spring to . but for some reason theres one part im not putting on . if you can help thanks:confused:
  2. Old Guy
    Old Guy Member
    Trans linkage
    The rod that connects to the steering column lever goes on the trans lever that shifts into gear. The other rod from the carb assy. is the kickdown for passing gear etc. goes on the trans lever that is next to the shifter lever. The small spring hooks to it and into a small hole in the cars frame in the direction of the front tire etc. It holds the kickdown lever foward when in normal drive position. If it is not hooked up, the trans has a tendency to not shift out of 2nd gear(passing gear or kickdown gear). Hope this helps.:)
  3. loopydog
    loopydog Member
    ontario
    762d@774d
    your the man
    thanks a lot i figured of the problem . i switched motors form 76stan to a 77 auto and could not figure out what i was missing .well i sat down and thought . hmmm same trans in each car dif motors hmmm i forgot to take the kick down off the one motor. thanks it realy helped out. :D
