Automatic floor shifter question
Discussion in 'Technical' started by orig72grabber, Feb 23, 2007.
  1. orig72grabber
    orig72grabber Member
    Barrie Ontario Canada
    72 Maverick Grabber #s matching 302, C-4 auto, A/C, tinted windows, P/S, Dark green/lime green stripes.
    Can anyone clarify if a 72 with floor shift has a 2nd rod up to the column to activate the reverse lights and neutral safety switch, if so is it the same rod as a column shift. Did an have the switches on the floor shifter.
    Randy:hmmm:
  2. Blown 5.0
    MS.
    1974 Maverick
    Most Mavericks ive dealt with has the switch on the trans, My 74 has a factory floor shift, but no second rod.
  3. Craig Selvey
    Yes...there is a rod that goes to the column. It is not for any switch....it is for the locking steering column.
    The neutral safety switch is on the tranny when it is a factory floor shift.
    I don't think it is the same rod as a column shift car.
