Automatic Transmission Floor Shifter Indicator
Discussion in 'General Maverick/Comet' started by NICK DOMINICK, Jun 17, 2014.
  1. NICK DOMINICK
    Burke, Virginia
    I am trying to replace the clear plastic shift indicator on my automatic floor shifter on my 1972 Maverick. It is held in place by 2 small bolts. A 5/32" wrench is too small and a 3/16" wrench is too large. I figure I need a 11/64" wrench but just want to make sure it is the right size before I order one and find out where anyone has found a wrench that size.
  2. 1973CometGT
    1973CometGT Member
    Orem, Utah
    1973 Mercury Comet GT
    When I changed mine, I just randomly went through my small ignition wrench set until I found one that fit. Sorry but I did not pay attention to the size it was. The set I have, has all kinds of odd sizes and have an open and closed end and are secured on a large key ring. Mine were Craftsman brand I have had for 30 years. Maybe Sears or someone else still makes them. Sorry it's not much help.
  3. simple man
    simple man Member
    Bunnell,Florida
    How about a small adjustable wrench? :D
  4. NICK DOMINICK
    Burke, Virginia
    The smallest adjustable wrench is too big, a socket won't even work because the bolt head is too close to the bracket it is holding on and the shifter rod.
  5. NICK DOMINICK
    Burke, Virginia
    I ended up getting the job done with a 4.5mm wrench. I googled a 11/64" wrench and found nothing. Every ignition wrench set I looked at did not have it as part of the set and it was not offered separate. It seems like it would have been a simple job but it was one of those PITA jobs that took way more time than you would have thought.
  6. 71gold
    why not have take A 5/32" wrench and filed it to a...11/64"...:rolleyes:
  7. CaptainComet
    I have a Pinto shifter in mine. It uses the same lens. I seem to remember this one being held on by a couple of those sheet metal curved fasteners that bite onto the post. You bend them a little and you can release them.
    Wondering if the Mav/Mustang shifters all are like Nick's?
  8. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Too tight for needle nose pliers?
  9. Craig Selvey
    Mine was the same as Captain Comet.
  10. NICK DOMINICK
    Burke, Virginia
    Because the 4.5 mm wrench worked.
  11. NICK DOMINICK
    Burke, Virginia
    I am not talking about the lens, it is the clear plastic pointer with the red stripe to show what gear you are in.
  12. CaptainComet
    a-ha! ... my pointer was held in that way too.
    That is a really odd size. I had to track one of those down to remove a giant interior panel in my Explorer ... I fully understand your pain. It was just one fastener, and it was sunk in a hole, a 4mm was too small and a 5mm was too big ... I had to walk away from it for a few minutes and calm down ... it was pure luck that I stumbled across this odd size in a cheap set of sockets that I got as a gift. Made my day .....
  13. simple man
    simple man Member
    Bunnell,Florida
    I think I have that "cheap" set of sockets too! The ratchet is made of tin and it has a square drive on one side and a ΒΌ" hex on the other. It's saved my butt a bunch of times! (y)
