automatic transmission lines
Discussion in 'Technical' started by EFIMAV, Jul 16, 2002.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    does anyone have a picture of the proper routing of the steel trans lines from the radiator to the transmission in a 74 200ci C4 maverick? Thanks
  2. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    trans lines
    It's actually basic. They run up the side of the trans they come out of, along the oilpan rail till they get to the crossmember. Then 90 deg to the rad side of the fitting another 90 deg to the rad. the up and into the rad. All bends are 90 deg bends.
