Axel removal and backing plate removal
Discussion in 'Technical' started by Blue Brick, Apr 29, 2014.
  1. Blue Brick
    Blue Brick Member
    Ok, before I waste money and get in way over my head. Is removing the axels and the backing plate just pull and replace? Is there a way to mess it up or cause damage?
  2. blugene
    Pretty straight forward. I try and not slide the axle across the seal or the end into the tube.
  3. Blue Brick
    Blue Brick Member
    Will it go back in as easily? How does it go back in? Will I need any parts?
  4. blugene
    You'll need the parts your replacing.. :hmmm:
  5. Blue Brick
    Blue Brick Member
    My bad I thought I added all that…
    Just changing the backing plate.
    Can the anchor pin just be replaced instead?
  6. 71gold
    is this an 8 inch?
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What year is your car (what rearend)? Why would you replace back-plates? They don't wear out.
    What are you trying to do? Replace axle seals & bearings? You need to be more specific for us to be able to help you.
  8. dyent
    dyent Member
    vancouver bc
  9. rthomas771
    The could get damaged in a wreck or car falling off jack stands or rust if sitting in the dirt for years...the list can get long. Brake shoes can wear a hole in them too if never greased when replacing the shoes.
  10. Blue Brick
    Blue Brick Member
    9 inch....
  11. Blue Brick
    Blue Brick Member
    Sorry thought I added all that… Just changing the backing plate.
    Would like a longer anchor pin.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Well you don't need to remove the axles to do that. There are 4 bolts that hold the back-plate on. Disconnect the brake lines from the wheel cylinders, and the parking brake cables. Don't really see how you could mess anything up.
  13. 71gold
    ...:hmmm:...
  14. mav1970
    But you still have to remove the axle to get the backing plate off of the axle tube and the new one on :)
    As Crazy Larry nentions, the backing plate is straight forward removal and you will also need to bleed the rear brakes when you are finished putting the new plate on - get yourself an axle puller and unbolt the axle retaining plate and the axle should come right out
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Doh! What was I thinking??
    But yeah, back-plate removal is easy.
