Axle flange gasket help
Discussion in 'Technical' started by t.ramsey, Apr 23, 2012.
  1. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I'm doing a crown vic disc swap and can't find the metal or paper gaskets locally. Has anyone used silicone on these?
  2. Earl Branham
    Lugoff, SC
    Easier to get some thick gasket material and make one.
  3. rthomas771
    I don't remember seeing a gasket between the axle flange and axle tube. I went and checked the parts I got from the JY and I see no indication there was a gasket. Looks like metal to metal contact to me. You could get a sheet of gasket material and make your own gasket if they suppose to be a gasket.
  4. injectedmav
    injectedmav Member
    Georgia
    The factory maverick 8" uses a seal just inside the bearing. The 8.8 from the CV uses a seal outside the bearing. Neither use a flange gasket to my knowledge.
  5. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    There is definitely a metal gasket on my 8", and I know it's not a 9". I messed it up and now I can't get the axle and flange back on correctly so I have to disconnect the brake line and straighten it.
  6. mercgt73
  7. injectedmav
    injectedmav Member
    Georgia
    Yep, my bad memory. You guys are right. I did have them before changing to discs on the rear. I'm not sure what the actual function is since there are sealed bearings on the axles and seals inboard of the bearings to keep the axle fluid in.:hmmm:
  8. DC12VOLT
    Everett, WA
    Cream 1971 Maverick
    Does that mean I should be able to just cut it and not have to worry about it anymore?
  9. injectedmav
    injectedmav Member
    Georgia
    I think it is mainly a dust seal, unless someone knows different.
  10. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Never saw a need for that gasket bit wonder if it is to help reduce brake noise transfer through the car.
  11. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I'm gonna order the metal ones and use them.
  12. 71gold
    none here...:thumbs2:
    the ones I have seen looked to have been...paper.
  13. Bryant
    ive never seen the reason for those. i see them on about 50% of the 8" and 9" that i have worked on. there should be no issues with leaving them out. especially if your switching to disk brakes. what ever reason ford put them in for is definitely out the window when doing a disk brake conversion.
  14. Earl Branham
    Lugoff, SC
    Might be just to keep them from squeaking, no metal to metal contact. Other than that....:huh:
