Axle measurements
Discussion in 'Drag Racing' started by 408w-maverick, Dec 19, 2013.
  1. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
  2. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    56.50 is housing measurements, I always see that number thrown out
    I believe its flange to FLange
  3. 408w-maverick
    Oklahoma City
    That's the housing, the axles them selves are what i need but thanks lol
  4. rthomas771
  5. lm14
    lm14 Member
    Iowa
    What rearend do you have in the car? 8" or 9"? Do you have existing axles for the housing? If so, use that length, it won't change with spline count changes.
    You should be able to measure the housing, write the numbers in the chart on the order sheet and get your axle lengths rom that. Do NOT take anyone else's answer for this, you are ordering custom axles for YOUR housing, measure YOUR housing.
    Also, if you have a 9" you need bearing and bearing retainer info.
    SPark
  6. 408w-maverick
    Oklahoma City
    Its a small bearing 9" cut to the same size as the 8" that came outta the car reusing the stock 8" axles with a full spool and 4:11's.
