Axle swap? Will it work?
Discussion in 'Technical' started by rsillmon, Feb 9, 2009.
  1. rsillmon
    rsillmon Sneaky Snake
    Caroline,VA
    Maverick
    I have a 70' maverick with the 8 inch rear with 4 lugs and a 77' Granada 8 inch rear with 5 lugs. I know the Granada rear width is about 1/4 inch longer on each side compared to the Maverick. My question is, can I just take the axles out of the Granada and stick them into the Maverick rear? Is there enough empty space between the spider gears where the two axles meet? Thanks Robert:)
  2. Bryant
    no there is not. you might be able to cut the diffenence off the spline end of the axles if there is enough spline on the shafts. we do this frequently. but the 4 lug axles usually have a smaller bearing diameter. this means that the bearing end wont be the same.
  3. rsillmon
    Caroline,VA
    Maverick
    Thanks on the infor, its time to bring out the wrenches:bouncy:
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    4 lugs and 5 lugs use different housing ends and bearings.
    No swap.
    The entire rear will bolt right in though.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    if the entire thing bolts in straight without any mods then why not use the axles off the granada along with the rear and just swap them?
  6. Acornridgeman
    Wisconsin
  7. don graham
    Can't see the thread?????:hmmm:
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Get your glasses, it is a very fine thread:D
  9. Acornridgeman
    Wisconsin
  10. ratio411
    ratio411 Member
    Pensacola
    Because the housings are different enough that the internal parts won't swap. However, the mounting points and dimensions relating to the car itself will allow the entire unit to swap.
