axles
Discussion in 'Technical' started by paul cooper, Dec 23, 2003.
  1. paul cooper
    paul cooper Member
    chatt. tenn.
    72 ford mav.73 mav. grabber
    How bad of a job is it to change my 4 lug axels out with a set of 5 lug axels? thank you Paul
  2. mavman
    mavman Member
    Arkansas
    on an 8" rear, remove wheels, drums, then remove the 4 nuts that hold the axle retainer and backing plate to the rear end housing. Pull out the axles, slide the new 5 lug axles in, and button it up. Pretty easy swap on a 8". If it's a 7.5", you're in for a real treat. Still not that hard, but I think the 8" is MUCH easier.
  3. 74Maverick
    74Maverick Maverick Maniac
    Glassboro, NJ
    1974 Maverick I bought for $500 8 years ago when I was 16. Since then I have invested $30,000 into it.
    swapping axles
    Little trick my dad taught me if the axles are tough pulling out reverse the drum on the stud. Put the 4 lugnuts on just a couple threads and use the drum as a slide hammer. The axles dont always come right out this will help.
    74Maverick, Thom
  4. paul cooper
    paul cooper Member
    chatt. tenn.
    Thank you for all the info.You all are real helpful no matter what is ask of you. MERRY CHRISTMAS EVERYONE PAUL:bananaman :clap: :bananaman :clap: :bananaman
  5. Craig Selvey
    For the 367th time (O.K.....Maybe not really).....you can't just swap "axles". You have to swap the entire axle housings. 4-lug and 5-lug 8" axle housings are different. Different housing, different bearings, ect.
  6. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Yep ...what Craig said!;)
