Back door weather stripping
Discussion in 'Technical' started by James91, Feb 7, 2013.
  1. James91
    James91 New Member
    Oregon Coast
    1974 Ford Maverick 4-door
    I recently noticed my car (1974 Ford Maverick 4-Door) was leaking water through the weather stripping on the rear driver's side door frame and made the mistake of pulling the stripping out to replace it. I happened to have some after market weather strips that had a tag saying they were for a ford maverick, but I've run into numerous problems trying to install them.
    It seems that the strip on the other door is glued into the cars plastic upholster trim which is glued to the car rather than flat onto the body itself (sorry if this explanation doesn't make much sense; I'll try to post some pictures tomorrow). I've noticed the strips are too long for the door frame and will not fit into the plastic U-shaped trim that the other door's stripping fits into.
    Could anyone give me any kind of advice on replacing the weather stripping for a rear door on a maverick? Any help would be greatly appreciated.
  2. 71gold
    Hi James,
    check and see if Auto Krafters has weather stripping for a 4dr...:Handshake
  3. Craig Selvey
    They don't...and nobody ever will.
    I would say you best bet is:
    1. Buy one for a 2-door and make it work
    2. Find a used one off a 4-door and replace your old one
    3. Find "pieces" of an old one, and piece it in to repair what you have.
  4. James91
    James91 New Member
    Oregon Coast
  5. Craig Selvey
    I am sure something like that could be used and function fine.
