Ball joint Install ????
Discussion in 'General Maverick/Comet' started by gold74maverick, Apr 30, 2009.
  1. gold74maverick
    gold74maverick Member
    NY
    74 Maverick 4 Door
    Hi,
    On my 74,it has the original ball joints... is this a do it yourself for someone with simple tools?
    Are they bolted or rivited in?
    Do the lowers only come pre-attached to the lower control arm?
    My tires are wearing on the inside and need to do something...
    Tire shop said they are worn and an aligement wont help:huh:
  2. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    both upper and lower could be done with basic tools.... incl. pickle fork, floor jack, jack stands (opt)
    the lower does come with the ball joint in it... you will have to replace the whole thing
    the upper is held in by bolts
    scale of 1-10 its a 1 :thumbs2:
    have at it
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    The uppers are riveted in from the factory. Easy to grind off the heads and knock them out, then replace them with the bolts in the BJ kit....
  4. Positively Ralf
    Yonkers, NY
    1974 Maverick
    question. what do ball joints do? I always see them discussed but never explained if they hold something up.
  5. Popbumper
    Popbumper PINTO unashamed
    Dallas, Texas
    Think of it literally as it is named. The ball joint works like the end of your long leg bone fitting into your hip. On a car, rather than keeping the spindle rigid to the control arm, the joint allows movement of the spindle/wheel in pretty much "any direction" (it gives the assembly "flex") so that the wheel/tire can adjust to changes in the road surface as you travel, but keep everything else in the suspension level while it is doing so.
    Hope that helped in some way.
    Chris
  6. Bob Wiken
    Fayetteville, Arkansas
    Great explanation Chris
  7. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    yep....thats what I did.
  8. Dave B
    How do you type that Homer Simpson drooling noise?? ARUGGGGGUUUUUGGGGGGGUUUUUU??
  9. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    anyone have a good way to get the ball joint rivets off without a grinder? Can I drill them out without messing up the arm? I don't have a grinder.
  10. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You could probably drill them out but a grinder would be better. A handy tool to have would be a dremel. I use mine to grind, carve, cut etc...
