ball joint???
Discussion in 'General Maverick/Comet' started by comet dad, Oct 15, 2003.
  1. comet dad
    comet dad Member
    Longview, Texas
    1974 Mercury Comet
  2. Mavaholic
    K8142 is Moog's number and is correct for the 3 bolt design. You talking about upper or lower A arm? Uppers, you can put in new bushings. Lower, its easier to buy a new unit. While you got it apart, replace the spring insulators and perch saddle. Mustang stuff is the same.
  3. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    What do you mean Mustang’s the same? Are u saying that I can use mustang rubber insulators for the springs. Do you know the part #? And what are Perch saddles?
    This would help me out… because I’ve got this really bad Skronk’n skweeak when I come to a stop.
    Thanks
  4. Mavaholic
    The suspension for 67-73 Mustangs are the same. Spring insulators are the same. The spring perch (saddle) is the pivoting part that the bottom of the spring sits on. The rubber bushing wears out and squeeks. CJ Pony parts has upper insulators for $2.95 each. Part # is CSI1. Spring saddles are part # CSS and are $19.95 each.
    http://www.cjponyparts.com/
  5. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Hehe...
    Sounds like my car! The upper Control arm bushings are gone! Country
  6. comet dad
    comet dad Member
    Longview, Texas
    1974 Mercury Comet
    wrong word
    sorry, wrong word......the upper ball joints and IDLER arm, not control arm......:confused: the alignment guy said a rebuild in on the arm in order to keep the car original.....wow he cares.....the ball joints seem to be correct so I'm gonna buy the ebay ones....alignment guy wants $40 each for his, so........thanks for the input.....Robert:bananaman :bananaman
  7. Craig Selvey
    Hey Comet Dad. As they say...."While you're in the nieghborhood" I would suggest you redo all the suspension on the front.
  8. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    Are there suspension kits that would be better than replacing all parts individually?
  9. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
  10. Mavaholic
    I dont recommend polygraphite and I really didnt like the upper ball joints supplied with PST kits. I ended taking mine out and throwing them in the trash. You'd be better off getting an OEM type kit from any Mustang supply house.
