Ballast resistor help
Discussion in 'Technical' started by x72COMETx, May 14, 2014.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    I just did a 302 swap and now i need the ballast resistor they have the ballast at napa auto for like $7 but i need help with wiring. My guess is that you run a wire from starter solenoid to ballast, then from ballast to positive side of coil. Is that correct?
  2. rthomas771
    The ballast resistor goes inline with the 12v wire going to the coil. The starter solenoid has nothing to do with it. Swapping engines doesn't require changing to a ballast resistor. You have a resistor wire under the dash from the factory doing that part of the job.
  3. x72COMETx
    x72COMETx Member
    Vallejo CA
    I was told thats what i need because i keep burning my condensor and points.
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    I also added a wire from my solenoid to positive side of coil to be able to get spark, without it it just cranks with no spark
  5. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Sounds to me like you will be getting 12 volts all the time all and that will kill/burn your points and condensor out... I think you have a bad solenoid or ignition switch. You may have a wrong ohm coil as well?
  6. mercgt73
    The coil only gets 12V during cranking (from the starter solenoid). Once the starter solenoid is disengaged, the resistor wire from the ignition switch provides a reduced voltage to the coil. If you bypassed the resistor wire, then it makes sense that you are melting points.
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    Yes i bypassed the resistor and yes it burned my points and condensor and it also killed my coil
  8. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    How old is the solenoid on the car?
  9. x72COMETx
    x72COMETx Member
    Vallejo CA
    About 4 months old
  10. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Look at your other thread. I posted the method for bypassing the resistor wire in it.
    If you need more details let me know there.
