Bellhousing Treasure Adventure!!!
Discussion in 'General Maverick/Comet' started by JeffScoggins, May 23, 2005.
  1. JeffScoggins
    JeffScoggins A.k.a. Conan Jr.
    Lake Charles, LA
    1970 Ford Maverick
    All I want for xmas is my bellhousing, my bellhousing, yes my bellhousing...
    If I can't find it, what will I do?...
    Put everything into another block...another block...another block...(music fades.)
    This is pathetic...what is one to do if they own a 1965 Ford and need a new bellhousing? (Since I'm using a block from that date...)
    I mean really, how hard can it be to find a simple bellhousing for a 65 Falcon, or 65 Mustang with a 200ci I6? :mad: :mad: :mad: :mad: :eek: :eek: :eek:
    You know what I should have done from the beginning? Check codes...but how should I have known the blocks changed in such a minute way? I've checked and checked and checked and decoded all the codes...and nothing about stupid changes in the size of the bellhousing or bolt patterns.
    I'm desperate...I've searched every junkyard (In Louisiana), salvage yard (In Louisiana), and website that there is to search...HELP PLEASE!
    Jeff Scoggins
  2. Jamie Miles
    Jeff, I know of a very, very old junk yard in a little town far, far away. They may have what you are looking for. I will be there this weekend and I will look.
  3. Acornridgeman
    Wisconsin
  4. Jamie Miles
    I think Jeff is looking for one for an automatic. :hmmm:
  5. Acornridgeman
    Wisconsin
    Sounds like a good opportunity to switch to 4 speed! (y)
    I'll look around for an c4 with a bellhousing on it yet from a 200. I gave a couple away this past winter.
  6. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    what are you needing a 5 bolt bell housing?
  7. JeffScoggins
    Lake Charles, LA
    1970 Ford Maverick
    I know where I can get a 4speed if necessary but would much rather have a c4. Im pretty sure its a five bolt. I'll check soon
    Thanks for the replies and if you find one jamie, measure the two top center bolts and it should be very close to 5.5" not 4 11/16.
    Jeff
  8. fan2488
    fan2488 Member
    spring,TX
    if its a 5 bolt i might have one on one of the falcons. but they are 1962 with the 6cyl. i will check this weekend
  9. bartikus
    bartikus Member
    salt lake city, ut
    hey all 62 falcons came with a ford-o-matic transmission or a 3 speed toploader.
  10. bartikus
    bartikus Member
    salt lake city, ut
    oh i forgot to add it you didn't know the ford-o-matic is a 2 speed
  11. JeffScoggins
    Lake Charles, LA
    1970 Ford Maverick
    thanks. Thursday, I will be taking some really detailed pictures with measurements so I can show you all my dilemma.
    Jeff
  12. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    Jeff.....You need a v-8 bellhousing and torque converter, it has the same pattern as the 289-302. the old 250's were actually a small version of the 300 straight six. they had 200 straight six parts in them. here is a link to help you along the way.
    http://fordsix.com/200-250.htm
  13. Acornridgeman
    Wisconsin
