Bellhousing wuestion
Discussion in 'Transmissions' started by bryson123, Jul 1, 2018.
  1. bryson123
    bryson123 Member
    california
    1972 MAVERICK GRABBER
    hi all would the t5 bellhousing from a 89 fox body fit up to my 71 302 motor? Thanks
  2. Krazy Comet
    Dismal Swamp
    I dunno what a '89 go body is, but all 302/5.0/351W & C have same bellhousing bolt pattern.
    NOTE Balance of early & late 302/5.0 engines is different. Install a late engine with a early flywheel(or the reverse) and you'll have a dandy paint shaker.
  3. rthomas771
    Late model bellhousing are deeper than early models. You will need the longer input transmission to go with it if you talking manual transmission. Don't know nothing about automatic transmissions
  4. dyent
    dyent Member
    vancouver bc
    Well, if you are going to use a T5, then you would be good to go! Then you would need correct flywheel and all related parts for conversion. Do you currently have a manual tranny behind your 302?
    David
    JL Mav likes this.
  5. Powerband
    Powerband Member
    NY's \H/
    should fit 157 T FW, remember the T5 bell clutch setup is pull-cable and the 71 car is push-rod...
  6. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    should work well, if it doesnt have a matching bellhousing then make sure you get the right one. the ones off the SN95 (late models) mustang are longer to accomodate a longer input shaft.
    as far as clutch mechanism... Im in the middle of the swap right now and am going hydraulic.
  7. baddad457
    Don't know if you know this or not, but make sure the firewall's well reinforced where the master cylinder's mounted to keep it from flexing, especially important if you're going to drive it a lot.
  8. bmcdaniel
