belly bar install
Discussion in 'General Maverick/Comet' started by hewitt46, Mar 8, 2012.
  1. hewitt46
    hewitt46 Member
    White Lake,MI
    71 maverick
    does it matter which i install first ...?? the engine or the belly bar?
  2. 71gold
    it does if you are installing motor and transmission together...:Handshake
  3. hewitt46
    hewitt46 Member
    White Lake,MI
    71 maverick
    well actually im not sure ...i just got the mav back from paint and the engine bay is pretty spotless ...not sure i want to risk scratching it.....how hard is it to put the trans in seperatly from the engine? i have only put in and removed with the trans attached....
  4. 71gold
    not bad at all...if you have a lift and transmission jack...:D
  5. Dave B
    I installed my engine and transmission in one piece, you just have to take your time.
  6. hewitt46
    hewitt46 Member
    White Lake,MI
    71 maverick
    so far your not very encouraging! haha... i do have a small trans jack and jackstands!! lol
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have always installed the engine and transmission together. Just have another set of hands to help. Belly bar shouldn't be an issue as the steering is in close proximity. If it is in the way it is only 2 bolts.
  8. 71gold
    was the belly bar installed at the time...:huh:
  9. Dave B
    Yup :D. .........
  10. Craig Selvey
    I would install the engine and tranny together, and you can do it without scratching anything....I DID!!
    Takes a few pieces of cardboard.
  11. CaptainComet
    Craig,
    Do you have the back end of the car jacked up, too? Looks like it.
    I just saw that trick somewhere else lately. I think it had to do with Shelby Cobras ... it was one of those ... :slap: "why didn't I think of that moments".
  12. mavgrab302
    Did you put those socks back in the sock drawer when you finished the install ? lmao... really, that is a great idea for chain padding...
  13. Craig Selvey
    Yes......get the back end as high as you can, and get the front end as low as you can. CAUTION: Front can't be too low. If the car is sitting on it's suspension, and once you drop the engine in, the weight of the engine will make the front end of the car even lower, possibly making it impossibe to get the engine hoist out from under the car.
  14. olerodder
    olerodder Member
    NorCal
    I pulled the 351/Glide out of the Maverick in one piece. The car was on jack stands on the rear and ramps on the front. I did take the belly bar out first then the transmission cross member because one the pan cleared the suspension, I have a Milidon 30926 pan and you need to slide the engine/trans forward then up at a pretty steep angle.............it really does need two people.................it just takes a little time and put plenty of blankets/cardboard just to make sure.
    Laying on your back (if you don't have a lift) is the pits, and then you have to put the convertor bolts in...........it's just a pain............IMHO
  15. hewitt46
    hewitt46 Member
    White Lake,MI
    71 maverick
    great advice guys! thanks
