belly bar on an i6 car?
Discussion in 'Technical' started by random hero, Mar 3, 2010.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    will it stiffen up the front of the car, or is it pointless? i already have one and plan to do the swap just curious if it will help with the stiffness an i6 car?
  2. PaulS
    Belly bars are there to support the bottom of the shock tower so they don't crumple under the weight of the engine bouncing around. If it stiffens the suspension up then you have some rotten metal where you shouldn't.
  3. random hero
    hudson valley
    1972 maverick
    :thumbs2: just the answer i was looking for thanks for saving me from wasting some time :Handshake
  4. 71gold
    put it on...
    that way you will know where it is when you do the V8 swap...:yup:
    ...RFF...:Handshake
  5. Mavman72
    Will the belly bar clear the pan on an I-6???:hmmm:
  6. Rando76
    Rando76 Member
    Claremore, OK
    It won't HURT anything, so I agree with Frank - just put it on so you know where it is. :yup: It takes about 1 minute to install.
  7. rthomas771
    I got one under my six :yup:
    The V8 doesn't weight that much more than a six. There's only 40 lbs difference between a 250 and 302.
  8. mav1970
    I would say that, if there is a way for you to stiffen up your chassis, do it. You don't want your chassis flexing and acting like a spring. It will allow your suspension to react more efficiently :thumbs2:
  9. PaulS
    Subframe connectors will stiffen the chassis but the belly bar won't do much. A nice twelve point roll cage with subframe connectors will make it nearly ridgid.
  10. random hero
    hudson valley
    1972 maverick
    the reason i asked was because a montecarlo bar sitffens the front end up...so y wouldn't a belly bar...but if u say it doesn't help ill take your word for it (y)
  11. 71gold
    ...some say it helps...
    some say it both ways...:hmmm:..."Belly bars are there to support the bottom of the shock tower." ..."the belly bar won't do much.":huh:
    i vote...helps
    it was put on by Ford for a reason...:yup:
    ...:bouncy:...
  12. PaulS
    Adding a cross member (which is what the "belly bar" is) keeps the two parts of the frame at the same distance aprt but it won't keep the frame from twisting at all. The biggest problem with sub frame cars is that they twist. The belly bar will not help that at all. It will make the front end more stable side to side but not do anything to keep the twist away. It won't hurt anything to install it - put it on. Just don't expect to feel much in the way of stiffer or better ride.
  13. Rando76
    Rando76 Member
    Claremore, OK
    I always wondered why they didn't put it on ALL (atleast the 250s) Mavericks since the weight difference isn't that much between a 302 and 250. :hmmm:
  14. rthomas771
    The early (60-65) Falcons, which were all 6 cyl, came with a belly bar. They were held in place using the same 6 bolts holding the engine frame mount to the shock tower. When the Falcon came out with a V8 option in mid '63 the belly bar was omitted but these V8 cars had torque boxes. This kind of makes a person question the original purpose of the belly bar intention.
  15. PaulS
    The early Falcons had torque boxes too. All subframe cars use them to tie the sub frmes into the body for support.
    The Falcons used some pretty thin material in the front end and subframes - even thinner that the 65-66 Mustangs, They may have needed the extra lateral support.
    Trying to second guess an engineer on a budget is like looking into the future - many possibilities.
