I am a local street stock racer here in the interior of BC, Canada, that is running a 347, but we are limited to 2V cast iron intakes only....can someone help or inform me which is the best flowing, largest 2V available? did Ford make some for Marine use, and large trucks different like GM did? thanks, and info and leads to buying one would be great from warm, western Canada, (+5 Celsius today) Shane
Well i have several early 302/ 289 2v intakes without egr i will do some reasearch later and let you know which is better. I used to race ford street stock class si o know what you are going through. Are you able to polish the inside of the intake? Does your track allow stock alum intake i have one of those to. I used to have to fight off the gm products i was the only regular attending ford for 15 years. I spent the first 5 years getting tore down every race night cause fords werent suppose to run that fast. The good ole days. Let me know what chassis you run. I still have some trick suspention parts and may be able to throw a few ideas your way.
