Best Floor Shifter
Discussion in 'Technical' started by MikeG747, Jan 23, 2006.
  1. MikeG747
    MikeG747 Member
    Arkansas
    What Automatic floor shifter is best to use for STREET/STRIP use? Hurst or B&M or other & which model?:drive:
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Hmmm.... depends on whether or not you want to 'hassle' with pulling up on a trigger to go from N to R and/or P - that and explaining to others how to drive your car should you need to let someone borrow it. :cringe:
    I had a B&M Hammer Shifter that worked GREAT. I now have the Hurst Quarter Stick - both seem to be fine. :shrug:
  3. madmav74
    madmav74 Member
    north dakota
    74'maverick strip car
    I use the B&M Z-GATE works great, simple, and economical
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    B&M Quicksilver here. No problems. It will be on the for sale forum soon however..
  5. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    B&M ProStick here....great shifter and very well built! Almost exactly the same as the Quarter Stick except for the replacable gate.
  6. grbmaverickmo
    Aquashicola, PA
    I vote for the hurst pro matic. Had one for years simple and not alot of moving parts to wear out.
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I vote for a manual tranny!
    Oh well, I tried... ;)
    When I had to run an auto, I really liked the Z-Gate.
    I had a Megashifter and a Hammer, didn't care for them. The Mega gave lots of 'issues' when driving day to day.
    The Z-Gate is less expensive and doesn't look fancy, but it is really easy to use on the street. Tough too. Not any frills to cause problems.
    My .02
    Dave
    Edit: I should also mention that the Z is good for strip too. Once in the forward gears, it acts like a ratchet shifter. You can hit it HARD into each gear without fear of a mis-shift.
  8. RabidCustoms
    I dont think you'll go wrong with either brand, pick one you like that matches your intended use and the style that will go with the interior.(y)
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I've had my B&M Star Shifter for almost 25 years. Only problem I have ever had was the small T- handle for the lockout was made of plastic and it broke almost right away. Happened to be in High School at the time and cast one out of aluminum, problem solved.
  10. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Cheetah makes the absolute best shifters. Ratchet shifters have the nasty habit of wearing out.
  11. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    I had B&M Z Gate in my 73...great shifter...Hurst Pro Matic 2 in my 72 also great shifter, no problens ever...
  12. Blown 5.0
    MS.
    1974 Maverick
    I have the B&M star shifter which is ten years old now. Never had any issues with it, Its probaly the only thing on my car that hasnt been replaced or given any trouble, And it looks like it was made to fit a MAVERICK.
  13. igo1090
    igo1090 Member
    catonsville, md
    quarter stick.
  14. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Hurst Shifters have been good to me:)
  15. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    B+M quiksilver in my Mav...since 1985 Works fine,
    My wifes Fairmont has a B+M Mega-shifter fitted with the short stick option, looks good and works good
