Best way to get to the windshield wiper switch?
Discussion in 'Technical' started by CommieHook, Dec 30, 2011.
  1. CommieHook
    CommieHook Member
    Hot Springs, AR
    1974 Ford Maverick 4-door
    Hey guys, I bought what is needed to convert the wipers to intermittent wipers. What's the best way to get to the old switch? #1 - Through the heater/AC control panel? If so, how do the control knobs (The little silver ones) come off? #2 - Or up from the bottom of the dash? #3 - By removing the instrument cluster maybe?
    Thanks for the help.
    CommieHook
  2. Craig Selvey
    I would remove the instument cluster, then remove the heater controls. This will give you better access to the wiper switch. You could possibly do it by reaching up from underneath, but I think that would be more difficult.
    The silver heater knobs just pull off. Sometimes you have to tug real hard with a set of plyers. Just don't hit yourself in the mouth when you do!!
  3. 71gold
    jack the car up...put on jackstands...pull the left...
    :hmmm:..no no no do what Craig said...:thumbs2:.
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    You can take a little L shaped flat screwdiver and release the little tab under the heater knobs. then they slid right off.
  5. Craig Selvey
    There are no little tabs on Maverick heater knobs.
  6. rthomas771
    I used a dental pick to remove the light switch knob so I wouldn't have to bend my screwdriver. Remove the cluster and heat controls. I stuffed my controller in the far left corner.
  7. CommieHook
    CommieHook Member
    Hot Springs, AR
    Thanks for all of the help guys, I got it done today. Works great, looks great. One observation, though. I think that Ford sharpened all of the edges of metal in the dash so that when you work on something in there you are guaranteed to score at least a dozen cuts/scratches on your hands and arms. Yikes!
    CommieHook
  8. darren
    Nope its not just Ford. I have the scars to prove it. Dont worry skin gets tougher.
