block id help please
Discussion in 'Technical' started by black396, Jan 12, 2005.
  1. black396
    black396 Member
    florida
    Comet
    I gotta block with the following. what size motor is this? thanks
    Charles
    D9AE-6015-ED 16
    8J28
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    According to sources it is a 79 - 351W
  3. black396
    black396 Member
    florida
    Comet
    a 351W as opposed to a 351M? Hmmmmmmmm. could it be a 302?
  4. maverick1970
    Missouri
    On a 351C/M the thermostat housing will be on the block where as a 302 or 351W has it on the intake. The fuel pump mounting on the 351M will have a vertical bolt pattern a 302 / 351W will have a horizontal pattern.
    The 351C uses a standard small block bellhousing bolt pattern but the 351M/400M has the larger 429/460 bolt pattern
    If you determine it is not a 351 C/M then look at the front of the block and compare the distributor and intake mounting surface, on the 302 the will be almost even in height on the 351W it will be over an inch difference
  5. black396
    black396 Member
    florida
    Comet
    Thanks Armed with this info, I will look when the sun comes up.
    Charles
    I oughta know this stuff
    Fla
  6. maverick1970
    Missouri
    I thought it was always sunny in Florida :bananaman
  7. black396
    black396 Member
    florida
    Comet
    it usually is, a torrent of adult malt beverages befell us yesterday, and the sun was hidden.
    It also was last weekend for the All Ford show @ Silver Springs. 961 cars, and about 20 to 18 Mav-Comets.
  8. maverick1970
    Missouri
    It's amazing what we can infict upon ourselves. Did you get any pictures to post?
