boring a 351w
Discussion in 'Technical' started by Yellow72Mavrick, Jul 28, 2006.
  1. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    what would be the biggest bore job for a early model (73 and below) 351w block, .040, .060 etc that would still be safe without running hot etc? I have an idea in my mind...Jim:huh: :)
  2. newtoford
    newtoford Member
    New Castle Delaware
    my friend has a 030 bore on the winsor in his maverick. runs great all day long. I think any think over 040 on almost any block and your taking a chance. you should get the block tested at the shop to be on the safe side .
  3. igo1090
    igo1090 Member
    catonsville, md
    generally, 040 should be max.
  4. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    be a maverick go .060 take awalk on the wild side
  5. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I am at .040 over on a 393 stroker. Ran 100,000 miles on .030 over. You are taking chances at .060, but if the block checks out, it can be done. I don't think I would run a strong performance motor at .060, regardless of how it checked out.
  6. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    You need to sonic check the block. Typically....they will go .060" over but may run into some heat issues in "daily driving" situations. Going .040" over usually gives no problems but, again, have the block sonic checked to see where and how thick the metal may be.
  7. RabidCustoms
    boring 351w
    your right.....351w's are boring:rofl2: :D just kidding.
  8. Jamie Miles
    Alto, GA
    I've had a few
    Don't know about a 351, but my dad's 302 was bored .060 and ran just fine all day long on the street. Temp gauge never went above 170.
  9. Thack
    Thack vision advicator
    Moreno Valley Ca
    Both my truck and mustang have the bore at .060 I'm using speed pro hyperutectic pistons.............sorry for the spelling.
  10. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    Like stated above, get it tested to see what YOUR block can handle. I wouldn't recommend boring all the way though, as you will not be able to bore the block anymore for a rebuild or incase you have a problem. I am the conservative type though. :rolleyes:
  11. mavman
    mavman Member
    Arkansas
    I've been told that .040" is max overbore. However, I have run several at .060+ and haven't had any problems at all, but all were concreted. I see no reason that you couldn't safely go .060" on a mild build. 351 blocks are a lot beefier than 302's.....
  12. papawdarrell
    papawdarrell papawdarrell
    Arkansas
    1973 Maverick
    When I was dirt tracking, I ran 351W's always .040 never had any over heating problems. Was running stock radiators not the better alum. ones.
  13. Jamie Miles
    Alto, GA
    I've had a few
    My dad's Comet had a totally stock cooling system, with the exception of the braided radiator hoses, which were only cosmetic.
  14. PaulS
    If you are trying to find cubic inches you should be looking at stroking not boring it.
    .030 will give you 5 Cu" and .060 will give you 11 Cu" If you are just cleaning up the bore go .030 and that will leave enough to bore it once more. I know that Ford recommends nothing over .030 but that is for racing where there is a lot of compression and RPMs. Do what you got to do man. Just think about all that can happen.
