Brake Booster and MC from a Subaru?
Discussion in 'Technical' started by 55crownvic, Dec 29, 2010.
  1. 55crownvic
    55crownvic Member
    colorado springs
  2. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    Any thing will work with enough modifications and fabrications, sometimes it's trial and error! thats what makes it FUN:yahoo:if you go for it and it works let us know. i'm working on a Geo metro booster and 96 explorer rear disc install my self and it fits great, now how it will stop is still up in the air, gotta finish alot of other things along the way:tiphat:
  3. 55crownvic
    55crownvic Member
    colorado springs
    Got any pics of the metro booster install? Or tips? I might try and find one in the upull this weekend.
  4. olerodder
    olerodder Member
    NorCal
    Although I will be running a manual disc front and drum rear I will be using a Ranger setup.............mainly because the Ranger unit is smaller. You may want to look at a Ranger setup as it will bolt to the existing bolt patern and of course it is a Ford product................IMHO
  5. Charlysalinas
    Charlysalinas New Member
    La habrá CA
    1974 maverick 250 all stock
    Hello every body ,, looking for info and parts on the Granada brakes swap
  6. Charlysalinas
    La habrá CA
    Granada swap parts
    Hi im new in the forum please help me to find the parts for my mav if somebody has a extra kit or knows of somebody who has them,, send a email please im in la habrá ca, luischarly83@yahoo.com thanks
  7. 55crownvic
    55crownvic Member
    colorado springs
    So you are running just the mc from the ranger, and not the booster, correct?
  8. mojo
    U might want to check the classifieds on this forum, there is a lot of stuff there for sale... Welcome to the Forum from Northeastern Illinois...:Welcome:
  9. Charlysalinas
    La habrá CA
    Ok thanks mojo
  10. maverick75
    discbrakeswap.com They have it all new in a kit :) OP have you thought about hydroboosting? If i get rid of my power setup thats what ill be converting to.
  11. Charlysalinas
    La habrá CA
    Thanks mav75 i would like it , if u dont need it no moré i buy it,, im looking something cheaper, but thanks. Hydrobooster i think is too much deal. Good luck on your project bro.
  12. Charlysalinas
    La habrá CA
    What kind of booster did u use?? No problems whit the suspensión tower?? U have disc brakes??
  13. diddie
    diddie Member
    indiana
    no pics avalible at this moment maybe get some on here this weekend it looks like it was made for it but it didn't come without some mods. bolt up is close but needs some adjusting i'm not sure on an original manual brakes car but i had to remove my complete brake pedal assy. and remove a spacer assy that is about 7/8 inch thick and cut/add/and weld to make pedal bracket butt up against the firewall due to the studs on metro booster are short. then had to add new attachmet to hook pedal to booster. i also am using mastercylinder for 96 explorer it will bolt to booster but a spacer rod has to be made for it to work!
  14. maverick75
    Mine had stock power disc brakes(they were available on 75-77 models). Everything fits fine and works well. But i want to swap to a manual transmission and it wont work with the power setup. If i decide to sell it ill let you know.
