Brake light switch.........
Discussion in 'Technical' started by Moneymaker 1, Apr 9, 2014.
  1. Moneymaker 1
    Panama City Florida
    Turn signal switch.........
    Melvin's list only turn signal switches for the Ford Maverick, one that fits a 1970 and one for 1971 and up, I am a bit confused, I thought the 70 was year specific, then the 71 and 72 were year specific and then 73 and up, am I wrong, did I just get bad information, I need to replace my turn signal switch in my 72 and want the correct one, please reply with correct information, and yes I have used the search function, that only confused me more :huh:
    http://www.melvinsclassicfordparts.com/pdfs/melvins-maverick-catalog-final.pdf
  2. Rasit
    Rasit Member
    SE Pennsylvania
    You mention a brake light switch and then say you need a turn signal switch. They are two different things. What are you looking for? The turn signal switch for your 1972 would be part #D2AZ13341C.
  3. rthomas771
    73-up used a different turn signal switch. 70-77 used the same brake light switch
  4. Moneymaker 1
    Panama City Florida
    Sorry it's been a long week/weekend. TURN signal switch is what I need, I was probablly thinking brake light because only one of my brake lights work, until the turn signal is pulled just right, will a 1970 Galaxy switch fit? EDIT: I see the part numbers are the same so it should.
  5. Moneymaker 1
    Panama City Florida
    Okay changed turn signal switch and now have both brake lights, BUT no left rear or right front turn signals, bulbs check out good and grounds are working, pftttttttt back to it tomorrow morning, open for suggestions :hmmm:
