Brake lights broblem X2!!!!!
Discussion in 'Technical' started by justin has a 74, Jul 21, 2010.
  1. justin has a 74
    kentucky
    Got A light working, now how about the right back side? BTW i cant seem to get my spark tester to light up for both and it is not broken:mad:
    Old cars are a pain when people have been hacking on them:16suspect
  2. Bryant
    need more info to give you beter advice. you need to follow the power flow. take your test light and see if there is power in bulb socket when the pedal is depressed.
    also does the running lights work?
  3. rthomas771
    A spark tester won't measure 12 volts...it measures 10,000 volts. You need a 12v test light
  4. justin has a 74
    kentucky
    Running lights work... i'm searching for a big volt meter.
  5. Bryant
    do you know that the bulb is good?
    try switching the bulbs?
    also if the turn signal switch is on and the key off it turn off the brake light for that side.
  6. justin has a 74
    kentucky
    lol ill go check, i hope its that
  7. justin has a 74
    kentucky
    Well that was it, thanks Bryant. I was chasing something that didnt exist!!!!
  8. Bryant
    any time.(y)
