Brake line flaring tool
Discussion in 'Tool & Shop Talk' started by fastback86, May 24, 2009.
  1. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Can anyone recommend a double flaring tool that isn't a cheap POS? I got the AMPRO from Rice World (Advance Auto) and I broke it after 5 flares. I took it back and got another but broke too. I don't think its operator error, It worked great in the begining. :huh:
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I don't know man... I broke mine from either Autozone or Advance, not sure. You'd think I would have learned my lesson about cheap tools, but then I got one from Harbor Freight. Haven't broken that one yet and I use it pretty often.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have 2 that don't work well. Now I just borrow one from Autozone when I need it. Works great and I don't have to buy it. I find it is all in the prep of the end before you try to flare it.
  4. facelessnumber
    Memphis, TN
    '71 Grabber
    Interesting. How exactly are you prepping it? :hmmm:
    All I do is use one of those roller type tubing cutters, haven't had a problem yet.
  5. maverick1970
    Missouri
  6. fastback86
    FL
    That's basically the same tool I had. I didn't file the ends of the tubes or use the drill bit to ream out the end. My problem was I broke the threaded part of the reamer tool.
  7. ultrastang
    ultrastang Member
    Arkansas
  8. maverick1970
    Missouri
    I looked at that kit and will probably buy it before the next brake project.
  9. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    Find one that is made in the USA and it will last a long long time . If autozone can`t get one made in the USA go to nappa or Oreilly .
  10. ultrastang
    ultrastang Member
    Arkansas
    I got my hydraulic flaring tool from this place:
    http://www.etooldirect.com/mastercool-71475-universal-hydraulic-flaring-tool-set.html
    However, I see they have gone up in price. When I ordered mine a few months ago, it was $289.99 and free shipping.
    I have seen this same set go for as high as $395.00 from other vendors, but even at $319.99, I would still say it was worth it. (y)
  11. maverick1970
    Missouri
  12. darren
    Deburr the cut edge and slightly chamfer it with a file. Clean the inside of the cut with the v-shaped tool usually on the end of the cutter.
  13. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Good tool you buy once and keep for a life time..
    Cheep tool you buy buy buy and so on
