brake lines
Discussion in 'Technical' started by Maverick Man, Feb 11, 2004.
  1. Maverick Man
    California
    anyone know what the stock NPT and Thread size on both ends on a maverick Brake line with a drum set up? or anyone use stainless lines on their maverick? if so what did you use?
  2. mercgt73
    im also interested in a complete stainless brake line set. I seem to remember seeing one specifically made for mavs/comets a while back somewhere... anyone heard of it?
  3. Mavaholic
  4. mercgt73
    They have the patterns.
    woohoo! too cool. check this out, under thier Printable Parts Catalog, choose Mustang. Maverick and Comet are on the last page! Not as expensive as I thought!
    Thanks Mav.
  5. Craig Selvey
    I supplied them with the disc brake lines for my car....so they should have those as well.
  6. Earl Branham
    Lugoff, SC
    Craig; all they have listed is power disc. Did you give them the lines for manual disc, or are they the same? Thanks,
    Earl
  7. Craig Selvey
    The front lines are the same. The line that goes from the prop valve to the passenger front line is different. I have one that I am going to take them for a pattern.
  8. ghenry36
    ghenry36 New Member
    Selah, Washington
    1973 Maverick
    Possi Third member
    I have several good gear ratios--- ring&pinions but I need the possi part. I would love to have one for 9inch and a 8 inch. Just just made a real good deal on a 9inch out of a 65Mustang but no possi. I would buy the whole pumpkin if ya can help? thanks Greg
  9. okibono
    okibono Member
    cali
    Hey, more brake line questions: if I'm running aftermarket front disc's, and drums in the rear, what brake lines should I get from Right stuff?
    thanks!
  10. Mavaholic
    It depends on what mc set up you are running. I kept the original drum set up and just added the disc so mine is all original type. If you converted to a disc mc when you did your swap, you will need those lines.
  11. okibono
    okibono Member
    cali
    i have the maverick stock replacement front disc/rear drum master...
