Doing the disc brake conversion, I ran into a slight problem maybe you guys can help remedy. Hard line leading to brake hose is 3/8. Granada brake hose and caliper fitting are 7/8.
7/8" is one big brake line i used the following napa part # 36649 8.26$ a piece (I've never understood while people run old parts on these cars) this was a '76 granada front brake hose it was the same as the maverick hard line good luck
3/16 is the fitting size on a non disc mav, the granada/mav disc hoses are 1/4 I used a simple steel adapter. They should be avaliible at napa or o reilley's
the napa line i referenced above was a 3/16" grenada line screwed into the mav front steel line and the new granada caliper
