Brake pedal / steering column linkage ?
Discussion in 'Technical' started by DJBerson, Oct 3, 2004.
  1. DJBerson
    DJBerson Member
    Boston
    1973 Maverick 2-door
    On a '73 Maverick, was there a piece that joined the brake pedal armature to the steering column shaft for support?? Can anybody provide a photo of their brake pedal assembly that might show the armature and anything attached to it?? There is a metal bracket on my armature with nothing attached to it.... and I suspect there is a part missing that used to stabilize the brake pedal from having side-to-side play. If I am not crazy, and this is true, I need the parts :) Can anybody help??
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Well, the side-to-side play is limited by two plastic bushings that snap-in. the only thing that holds the pedal (on a '73) is the dowel pin and clip...
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    T.L. is right ... even if the plastic bushings were worn the play should be no more than a couple of millimeters either way ..
  4. Mavaholic
    Are you talking about where the pedal assembly bolts to the bottom of the steering column and dash? Actually if I remember correctly, it bolts on the top side of the bottom but its all sandwiched together for strength.
