Brake Problem
Discussion in 'Technical' started by 4dr73mav, Oct 18, 2004.
  1. 4dr73mav
    4dr73mav Member
    Weld County Colorado
    1973 4dr Mav V8
    I was driving home from Northwest Arkansas on the interstate when I started to exit, pressed the brake pedal, and the pedal went to the floor. The brake light came on and I was barely able to stop.:eek: Luckily, if I pump the pedal, the brakes will build up pressure and start to work again. This works until I let off the brake pedal, then the next time I press the pedal, it hits the floor.
    Any ideas what this could be?
    Thanks,
    Jonathan
  2. 71gold
    4dr73',
    sorry to hear that :eek: .
    check the master cyl. and see if the front or back bowl is empty. that will give you a hint as to what end to pull down and check the wheel cyls...frank...
  3. 4dr73mav
    4dr73mav Member
    1973 4dr Mav V8
    I checked the master cylinder and the back was low but not empty. I thought it might be the master cylinder, but I'm not sure. jack up the back axle tomorrow and see about the wheel cylinders.
    Jonathan
  4. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    Sounds like a master cylinder problem to me. Even if the bowls are not empty, what happens is that the internal seals fail and although the fluid does not escape, pressure does not build up to apply the brakes. This has happened to me several times over the years, including coming off the interstate once, similar to your experience. Definitely not cool! :eek:
  5. Craig Selvey
    I have also had a brake line bust doing the exact same thing.....look for a busted brake line...rubber or steel.
  6. grabber37
    grabber37 Member
    New Mexico
    1971 Maverick Grabber
    Sounds like the master cyl to me.
  7. 4dr73mav
    4dr73mav Member
    1973 4dr Mav V8
    The new master cylinder came in today. It's too bad I have to work this evening. Looks like I'll be installing the new master cylinder tomorrow afternoon.:smash: :smash:
    Hopefully this will fix the problem. I'll keep everyone informed.
    Jonathan
  8. 4dr73mav
    4dr73mav Member
    1973 4dr Mav V8
    It worked
    The new master cylinder did the trick. The brakes work better now than when I got the car.:bananaman Thanks for all the help. I'll get some pictures of the engine bay up in a few days.
    Jonathan
