Brake problem
Discussion in 'Technical' started by duster70, Mar 22, 2006.
  1. duster70
    duster70 Member
    Houston, TX
    1970 Maverick I-6 automatic
    something is wrong with my Mavericks brakes. it is a 1970 2 door with an inline 6 and column shift. I put it in drive and accelerate a little bit, just enough to get it moving and ill press the brake pedal and it wont brake at all. I have the press the brake real real hard to get it to barely stop. I was researching brake problems online and from the information i found i think the master cylinder has no brake fluid and i will have to buy some and refill the master brake cylinder. I also read that i might have to bleed the hydraulic system or something. Also read that there might be a leak in the brake hydraulic system. I read that maybe the brake shoes were worn out, but according to the previous owner he installed new ones. Any suggestions???
    What kind of brake fluid should I use with the car??
    How much would a mechanic probably charge me to fix the brakes??????
    How much would they charge to fix the leak or bleed the brake system or whatever????
    Pleases answer these questions so I can find out what to do.
    Thanks alot and I really appreciate everyones help!
  2. Mavaholic
    You definately have a leak. Was both reservoirs empty? Dont know what it cost to have someone else do the work but you can try filling the mastercylinder up and bleeding them yourself first. My opinion about brakes is if your not sure of what your doing, get someone who is. Brakes are the most important system on the car.
  3. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    where in houston are you?
  4. Jamie Miles
    Alto, GA
    I've had a few
    Use DOT3 brake fluid. Sounds to me like you need some help with this.
  5. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Get some help...If your brakes won't stop the car,Ya' don't need to be driving it...especially the way other people drive....Just my:2cents: (y)
  6. duster70
    duster70 Member
    Houston, TX
    I live in the Southwest area of Houston, on Westheimer and Hillcroft, but my car is in Needville, near rosenberg. I know that one of the reservoirs has fluid but one doesnt. As far as filling the master brake cylinder with brake fluid, that i can do, but bleeding the brakes myself i dont know how. How do you bleed the brakes? there is a mechanic shop near where my car is, but I need an idea of how much they would charge so i can get some money and then go.
    Thanks much for your comments
  7. 71gold
    look on the back side of your wheels to see if one of them is wet. that will give you an idea of the one that is leaking...frank...:bouncy:
  8. Jamie Miles
    Alto, GA
    I've had a few
    Ok, here goes: to bleed the brakes, fill the Master Cylinder with fluid. Get a piece of clear tubing (Home Depot has this) and put it over the little nipple on the bleeder valve. The bleeder vavle is on the back side of the wheel cylinder just above where the steel (rear) and rubber (front) brake lines screw into the wheel cylinders.
    Get a clear plastic bottle and fill it about 3/4 with brake fluid. (old Gatorade or water bottles work fine for this) Submerge the other end of the clear tube in the plastic botte. Open the bleeder valve and pump the brake pedal until air bubles stop comeing out of the clear tube. Stop about every 6 or 7 pumps and make sure the Master Cylinder still has plenty of fluid. When you are sure there is no more air in that line, close the bleeder valve BEFORE takeing the clear plastic tube off. Move on to the next wheel and repeat.
    You want to start at the wheel farthest away from the Master Cylinder (passenger rear) and work your way to the closest wheel (drivers side front). In other words, bleed the passenger side rear wheel first, the drivers side rear wheel second, the passenger side front wheel third and the drivers side front wheel last.
  9. duster70
    duster70 Member
    Houston, TX
    ok cool thanks alot man ill try it this weekend!
  10. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Before you try to bleed your brakes you should find out if you have a leak or bleeding them will do no good.. Dean
  11. duster70
    duster70 Member
    Houston, TX
    alright thanks
  12. blugene
    Yea Duster you need to know where the leak is and which parts are going out when you do fix the leak. The hydralic parts are inexpensive and not too hard to install with the right tools and tech support which you have here.;)
    I too have brake question.
    Which resivour is for the front on a 73 w/drum drum and which is the front on 74 w/disc drum? I'm thinking they are opiset.
  13. Jamie Miles
    Alto, GA
    I've had a few
    They are the opposite on the '73. On the '74, which ever is bigger is the front.
  14. blugene
    My 73 has the same size front and back.?
  15. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    The brakes are your life guy.. If you dont know what to do then find some1 to help you. FIRST find the leak, either a wheel cylinder or a broken brake line,or possibly the master cyl has become porous and is leaking. solve the leak first then think about the bleeding of your system.. as some have said start with the Pass side rear, then driver side rear ,then front pass side,and then finish with the driver side frt.. If still no brakes then master is fubar. Best of luck and happy motoring:2cents: :D
