any suggestions on where to look and what to check, im completely clueless on this type of work. I believe it has to do with the emergency brake, as i use it quite a bit, since i need to adjust my linkage properly so it will go completely into park
alright i'll check it out in the morn....anybody got a pic of what it looks like? so i know im looking at the right thing..... thanks, jon
its like a button. when the peddle is at rest the lights are off because pressure is on the button. when you hit the brake though the peddle comes off the button and causes the lighst to come on. so when your unser the dash look for something like that goodluck
this is mounted on the end of the...master cylinder rod. i don't know of an adjustment...(may be sticking). ... ...
