Brakelines 70 Mav
Discussion in 'Technical' started by Dianne, Jul 26, 2013.
  1. Dianne
    Dianne Member
    Nampa, ID
    1970 Ford Maverick, 1973 Grabber, 1973 Pinto Wagon, 1978 Mustang King Cobra II, 2004 Mustang Convertible
    Does anyone know where you can get front brakelines for a 70 Mav reasonable? Need one on each side...
    Thanks!!!
  2. rthomas771
    You could bend and flare your own lines reasonably
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
  4. Dianne
    Dianne Member
    Nampa, ID
  5. Craig Selvey
    The rubber lines are impossible to find.
  6. rthomas771
    Are you saying that you know how to un-bend stuff instead of bending stuff? :hmmm:
  7. predfan2001
    This is true. It's worth the effort to go ahead and convert to 68 Mustang or later Maverick hoses. I went with Mustang hoses, they'll always be available.
  8. 71gold
    what all is involved to do this?
  9. predfan2001
    I bought 2 used Mustang hose brackets to bolt to the frame to hold the hose (same location as a 68 Mustang). Installed Mustang hoses and wheel cylinders. The factory Maverick hard brake line was too short so I made another line to tie them together.
  10. fastfords
    fastfords Member
    East Tennessee
    70 Maverick, 71 Comet GT, 72 Sprint, 75 Comet, Maverick Stallion
    For the rubber lines I bought steel braided lines from Just Breaks off of E-bay, and for the steel lines I bought a kit from " The right stuff". I can not tell you how they fit because I am still working on the engine bay/front end, but they mocked up ok.
  11. Dianne
    Dianne Member
    Nampa, ID
    I'm not good with that stuff or mechanical. I can do body work and paint only, sanding and so on... :(
  12. Dianne
    Dianne Member
    Nampa, ID
    I attached 3 pics he took for me. I can show him the 68 mustang post you did. But doesn't anyone have these lines somewhere?
    Banjo fitting 3/8"
    Female end 7/16 by 24
    Complete hose.. approx 19.5" -20 " in lenth left and right specific
    Dianne
  13. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Those hoses are obsolete. You might check with a shop that makes hydraulic hoses to see if they can use the metal ends and create new hoses
  14. Dianne
    Dianne Member
    Nampa, ID
    David, the mechanic, is going to try the Mustang thing that was posted by predfan2001. He read the thread also. This car is a pain ahahahaha But worth it!
  15. Dianne
    Dianne Member
    Nampa, ID
    Has anyone tried what predfan2001 is talking about using the Mustang parts?
