break-in ceramic coated headers
Discussion in 'Technical' started by EFIMAV, Aug 10, 2008.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I have the Doug thorley headers and can't seem to find the break-in procecures for these. Any ideas?
  2. newtoford
    newtoford Member
    New Castle Delaware
    run 'em, retighten the bolts, repeat? ;)
    but really, i didnt realize ceramic had a break in procedure?
  3. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Before you install them wipe them down with alcohol.
    Before ya start the motor, wipe them down with alcohol to remove grease and fingerprints as they can burn into the finish
    Once cleaned, start the engine. Run for about 5 minutes. Shut it off and let cool.
    Repeat for 10 minutes and let cool.
    This should cure the finish and help it last longer.
    Got this info from the company that coats them.
    Torque the bolts after the second cool down
  4. Dave B
    I remember reading something like that, I thought it came with the headers? but thats what I did, I made sure they were clean before I started the engine.
  5. EFIMAV
    EFIMAV Member
    Davenport Iowa
    Thanks, I'll follow the 5 minute and then 10 minute start up/cool down idea.
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I will definitely remember this when I put my new headers on!
    Thanks Bob.
  7. 72MAVGRABHER
    Roanoke, Va.
    Ditto...
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Something else that may or may not be of issue to you...
    Jet Hot says that you should never break in an engine with coated headers installed. They suggest you break in the engine first, then install the coated headers.
    So...
    No coated headers on a new engine.
  9. blugene
    I think I know why...:(
  10. hotrodbob
    hotrodbob Member
    First start-up with a new engine really puts out a hot exhaust. If you are also breaking in a cam the idle has to be up and there is no air flow over the headers and they will burn at the bends.
