break light came on and I looked to find this.
Discussion in 'Technical' started by russellgaspard, May 8, 2015.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    Can anyone tell me what happened and what needs to be done to fix it?
  2. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    1969.5 Maverick 71 Comet G.T. 76 Comet 4 door 61 Falcon x2 60 Frontenac
    Blown wheel cylinder
    71gold, Craig Selvey and Static like this.
  3. tody
    tody Member
    cologne, germany
    change them on both sides...
  4. 71Mavrk
    71Mavrk Member
    Nevada
    ... and the hose too.
  5. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    If the shoes are soaked change them also, and clean out the drum and the backing plate.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    All the above.
  7. Rasit
    Rasit Member
    SE Pennsylvania
    You probably already figured out that you shouldn't drive it until it's fixed. If your not comfortable working on brakes, find somebody who is. If you still have a good pedal, you won't for very long. Once air enters the system you might be able to pump up the pedal and will only be working off front brakes. Emergency brake will still work.
  8. mav1970
    Well, at least, you know your brake light works :huh:
    71gold likes this.
  9. scooper77515
    Not a difficult nor expensive job, if you are comfortable doing your own work.
    Do one side at a time, so you can reassemble the springs and arms and plates all in the correct order, looking at the still-assembled other side for guidance.
    Don't ask me why I mention that...:slap:
  10. mav1970
    You do that for the same reason that I do that :biglaugh:
  11. 71gold
    ...and remember they are a mirror image...
  12. tody
    tody Member
    cologne, germany
    ...and even the shop manual only shows one side ...
