Brighter brake and turn signal lights?
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Aug 5, 2018.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    Anything I can do to have brighter ones? My wife almost hit me when I was turning off and she swears she didnt see them? I think she just wasnt paying attention as she also ran up on me when I slowed for railroad track crossing before.
    Either way...what's a plug and play option? Thanks!
  2. Krazy Comet
    You'll get 19 recommendations for LED, but lenses become less transparent with age and the reflectors also dull.
    Polishing lense inside and out, plus using reflective paint inside housings improves light output by 100 to 500%. There is paint marketed for such and I used metal tape inside my Fairlane housings.
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Paint the inside of your taillight housings with FLAT WHITE PAINT .. not Silver .. It reflects well and is highly visible It will make a dramatic difference .. Brighter bulbs while you're at it ..
    Cometized
    (Chip)
    Crazy Larry and satchelmcqueen like this.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    LED recommendation #1
    After the police pulled us over in the Comet for no brake lights or turn signals, I started looking around for something better. Paint can make a huge difference both in the tail lights and instrument cluster. However I wanted something more. With the Comet, we converted the reverse light to another tail light and added these red led bulbs.
    https://secure.cougarpartscatalog.com/plasma2.html
    satchelmcqueen likes this.
  5. satchelmcqueen
    north georgia
    Will do. Thanks.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    How old are the bulbs that are in there now? They get dimmer with age. New 1157 bulbs and painting the inside housing white as suggested earlier should do the trick. LEDs just look stupid. I love them for many other things (gauges, instrument cluster, side marker lights, dome light), just not tail lights.
  7. satchelmcqueen
    north georgia
    Bulds are about a year old. Standard old style. Ill try white paint and some led buld replacement type I suppose.
  8. 71gold
  9. 71Mavrk
    71Mavrk Member
    Nevada
    Flat panel LEDs from eBay. Sequential. Super bright stop and back up.
    Kriscole94 likes this.
  10. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Just an FYI some LEDs won't fit under the lenses. I wasted a couple hundred on some that won't....be careful.
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    They look ridiculous.
  12. satchelmcqueen
    north georgia
    i cant see the pic
  13. 71Mavrk
    71Mavrk Member
    Nevada
    jasonwthompson likes this.
  14. Paul Masson
    1971 Grabber
    I bought a set of Digi-Tails LED taillights. The only thing with them is that they are modeled after 1970 lenses, which do not have two extra indents that the 71-77 lenses have. Luckily, I had a set of 1970 lenses and it worked out. You can select either normal or sequential. My kit came with an electronic flasher and I purchased a second electronic flasher for the hazard lights. Watch the polarity of the switches, I had to switch the wires inside the connectors by releasing the clips and swapping contacts on harness.
    https://digi-tails.com/product-categories/1970-77-maverick
    31120855_10156811959233274_1530041159571734528_n.jpg 31131035_10156811959308274_5644562980952604672_n.jpg 31100301_10156811960088274_1819204570123862016_n.jpg 31143724_10156811960533274_6701647727777808384_n.jpg
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
