bucket seat brackets
Discussion in 'General Maverick/Comet' started by mcmavv, Jan 20, 2003.
  1. mcmavv
    mcmavv Member
    ontario,canada
    76 mav
    does anyone have any pics of these brackets.none of the cars ive stripped had buckets,but i did manage to buy a couple of sets of what i was told were mav brackets.im going to be selling all my mav stuff soon so i want all my parts info to be accurate.by the way when its all ready to go it will be posted here weeks before anywhere else,and ill try to get pics of all items.
  2. MrHoba
    MrHoba Member
    Medford MA
    1972 Ford Maverick
    Here's a picture of the seat brackets I found, it took me just about 8 months to find them and I paid way to much.
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Looks correct to me...
    They look just like my brackets that I just primed and sealed.
    Mine are from a '74. I assume that they are all the same.
    Seth
  4. mcmavv
    mcmavv Member
    ontario,canada
    76 mav
    photos confirm that i have the correct brackets,except for the caps you can see on the bottom bracket bolts.are these caps specific to mav/comet ?,do they go on both outside brackets?just happens i have one lonesome extra piece with those caps on it but i have no idea what car they came from.thanks alot for the pics they are a great help.by the way how much was too much?
  5. RudyD
    RudyD Pretend Mechanic.
    Ft. Collins, Colorado
    1970 Maverick.
    Am I correct in thinking that you could just get the brackets off of two bench seats at a salvage yard and it would work the same. I think someone said something like that a long time ago.
  6. gsjohnson
    gsjohnson Member
    Pasadena, California
    72 Maverick 5.0 EFI
    The spacers on the studs should go towards the tunnel side of the floor & they are unique to the Maverick/Comet. Without these spacers the seatswill tilt towards the inside of the car. When using non factory buckets without the rails, you have to build your own spacers. The bench seat rails are not interchangeable with the buckets. Hope this helps.
  7. Mavaholic
    I remember reading that a guy used 2 sets of bench seat rails for a set of buckets. You would have to make your own spacers cause I believe bench rails are lower than buckets, but it should still work. Probably closer than any other rail you try.
  8. gsjohnson
    gsjohnson Member
    72 Maverick 5.0 EFI
    I just completed this swap from a bench to factory buckets. The bench seat rails not only don't line up for mounting to the seat, but the heighth is different. You can make anything work, but these are far from a bolt in. Hope this helps.
  9. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I purchased some bucket seats and the brackets were removed for shipping. Which side of the seat should get the lever for moving the seat forward and back?? Thanks ...
  10. gsjohnson
    gsjohnson Member
    72 Maverick 5.0 EFI
    I believe the drivers side is on the inside & the passenger side is towards the outside. I'm a little unsure, but I can check my car tonight, if someone hasn't posted the correct answer by then.
  11. gsjohnson
    gsjohnson Member
    72 Maverick 5.0 EFI
    Okay, I checked my buckets last night & I was wrong. Both adjustment levers will be on the left side of each bucket.
  12. dmhines
    Cumming, GA
    Thanks ....
  13. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    I tried to use the bench seat brackets, they are not even close. Don't bother, you can fabricate something easier.
