Bucket Seats swap
Discussion in 'Technical' started by Zip4747, Nov 15, 2012.
  1. Zip4747
    Zip4747 Member
    Philly PA
    1971 Ford Maverick
    I recently bought a set of Bucket Seats from a 1971 Ford Mustang Mach 1. I am trying to install them into a 1971 Maverick that had an orginal Bench seat. I have the tracks & all for the Buckets any ideas what would be the best way to make them work.
    Thanks
    Joe
  2. mercgt73
    Bolt the tracks to the seats. Drill the four inside holes for the tracks to mount to the floor (the outer four holes from your bench can be re-used). Install and drive it.
    Am I missing something? What is the problem you are having?
  3. Zip4747
    Zip4747 Member
    Philly PA
    1971 Ford Maverick
    It looks like it's that easy but usually never works that easy for me. Was just wondering figured someone would have already done something similar on here. Thanks for your advice.
  4. Tannersg1
    Tannersg1 Member
    Classified
    Shims, spacers, reinforcement for the inner bolts........
  5. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Drill the new holes, and then weld in some re-enforcements so you don't tear your floor pan apart.
  6. rthomas771
    No need to weld...you can use big washers for re-enforcment.
  7. Craig Selvey
    We presume you have MAVERICK bucket seat tracks?
  8. Zip4747
    Zip4747 Member
    Philly PA
    1971 Ford Maverick
    Cool Thank Everyone for your help.
  9. rickm
    rickm Member
    Owosso Mi
    Would you need Maverick tracks if your going to shim and adjust the height of the Mustang tracks ? I thought that you need Maverick tracks just to get level ?
  10. rickm
    rickm Member
    Owosso Mi
    Bump for question answer
  11. Dave B
    Just for you Rick.. Mustang seat tracks do not work very well in Mavericks, since the profile of the Maverick floor differs from the profile of the floor in a Mustang. It's not that it can't be done, it just won't work very well, without more work than it's probably worth.
  12. Zip4747
    Zip4747 Member
    Philly PA
    1971 Ford Maverick
    Ok How can I tell which seat tracks are from a Maverick or Mustang.
  13. 71gold
    these should give you an idea what...Mustang tracks look like...:yup:
  14. rickm
    rickm Member
    Owosso Mi
    Zip I was going to make a template out of cardboard for the placement of the bolt holes. With this I would find if any of the holes would be on a rounded surface. If not I would think it,s just a lot of shiming to get the right height and pitch. If anybody's used Mustang tracks they can jump in at any time PLEASE. Rick
  15. 71Mavrk
    71Mavrk Member
    Nevada
    The attached diagram may help
    70GreenMonster likes this.
