bucket seats
Discussion in 'General Maverick/Comet' started by HOMERMAV, Dec 15, 2008.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    what would be a good swap in for buckets if i cant find a good set of mav buckets.
    thanks john
  2. Acornridgeman
    Wisconsin
    71-73 Mustang high backs is what I have. They are very close to the Maverick seat - just need the correct tracks.
  3. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    I want a little more comfort so I went with 90 mustang seats on LDO MAV seat tracks .
  4. Duck Tape Mav.
    Vilonia, Arkansas
    I got some mid 60s mustang seats I'm in the process of installing. I'm switching from a bench seat, so I just used the mustang tracks on the inside rails and put the mav bench seat rails back in the outside slots. I'm punching the holes in the floor for the mustang tracks since I have to punch them already, I just spread them out. Only problem is getting under the car to put the nuts on the inside bolts. And I'd suggest measuring them out, not setting the seats in and marking with a marker, but me being impatient, made the holes about a half inch off, and will have to patch the extra hole up later. Other than that, not a hard swap. Plus you can't beat free.
  5. mrskydog
    Muskegon MI
    Hey Eric ,I have a set of 1972 High Backs out of a mustang I plan on installing in spring. What seat track setup did you use. any modifications?
    Kirk
  6. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    I have a pair of bucket seats out of a mid-80s Bronco II. does anyone know if they will fit in my 75 Mav 4 door?
    Thank Y'all
    Texasjack
  7. Bob Wiken
    Fayetteville, Arkansas
    I have a set out of an 80's mustang. They don't come close to fitting but since the drivers seat is electric, I'll make them work.
    a few inches of C channel at each mounting point some shims and just make them fit? I hope heheh
  8. Acornridgeman
    Wisconsin
    Kirk,
    I just used the regular Maverick tracks and all the spacers. My car originally had a bench. Seemed to fit real nice when I put it all together to drill the holes for the inner rails. I have them out of the car at the moment or I would take a picture. I may have to tweak the spacers a little because I'm using a thicker pad and carpet set up than the factory put in. But the basic Maverick bucket tracks fit the Mustang seats great.
