Building own S.F. conectors-Ideas?
Discussion in 'Drag Racing' started by 5.0paul, May 17, 2005.
  1. 5.0paul
    5.0paul Member
    Peace River Alberta Canada
    Maverick
    I picked up some 1 1/2 sq. 1/8th inside today. I can use advice on the shape of the connecting end. Also the best place to weld on the subframe. Thanks.....Paul
  2. Burlap1
    Burlap1 fat lazy truckdriver
    Urbana ny-wine country finger lakes wines are best
    1983 f-150 4wd,1971 cougar parts car,1973 maverick parts car,1970 maverick formerly a gramma's grocery getter,1984 f-250 460 powered,1976 f-350 u-haul,and some chevy's
    if i can find my camera i can send pics of the frame connectors on mine.they were custom built.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    here is some that was on a car I had.
  4. Burlap1
    looks like the ones on my car too.
  5. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    With 1 1/2" sq. tubing you should be able to notch the subframes and get the tubing up inside it. Then you can weld the connector to the subframe and possibly get part of the floor tied into the connector as well. I like to overlap the subframe by at least 12". Be sure to tie the subframes to the rocker panel with a "kicker" bar. Also, you can use a tubular driveshaft safety loop from one of the chassis companies and weld it from one connector to the other. This not only protects from a dropped driveshaft but it helps tie the car together from side to side. We use two tubular loops.....one in front and one as far back as you can get.
