Bump starter
Discussion in 'Other Automotive Tech & Talk' started by Mobiledreams, Jun 1, 2025.
  1. Mobiledreams
    Mobiledreams Member Supporting Member
    Buffalo WV
    1976 Maverick
    Does anyone know if anyone make a bump starter for the old fords. Car cranks but wont start after sitting. got gas, I need to check spark at coil. No help available and only two hands. I had a home made bump starter where I could push a button and cross the solenoid with one hand and hold the screw driver 1/4 inch from ground with the other. but it seems it finally found a good hiding spot.
  2. TeeEl
    TeeEl Senior Member
    Colorado
  3. Mobiledreams
    Buffalo WV
    1976 Maverick
    Thanks found them. I was doing the search with the wrong search words.
