if nothing else this mav. will have lights. today i mounted my 69.5 bumper lights.( thanks jerry) i now have the light upgrade, the clear sport lamps with amber bulbs that work for the parking and turn lights in them. the bumper lights have clear 2057 bulbs. the low side works with the brights on and the high side works with the lows on. to look like fog lights with the low beam headlights. i made a wireing harness and hook them to the drivers side stock headlight plug. used the pass. side plug to drive the relays for the the headlight upgrade. it took longer to write this than it took to do the lights. still looking into changing the lens in the grille to the frosted ones...frank...:bananaman :bananaman
and i have the bobcat tail lights with 2057 bulbs and 2056 backup light bulbs with 2825-w5w bulbs in my side marker lights. also did the 2825 bulbs in the inst. cluster. now i am burnt out just thinking about all thoes bulbs..frank...:bananaman :bananaman
and today... earl and i were talking sunday about putting the fan motor on a relay. so today i did. when switched on it excites the relay and puts a straight 12 volts to the fan switch. also i put the ele. choke on the same relay can anyone think of anything i have missed? this is what you get into when you have 8 wk. to recover from a knee operation. the last knee operation i had i built my house. this is more fun. up an down thoes ladders were hell...frank...:bananaman :bananaman
Frank; did the fan work any better?????? I haven't gotton around to it. Were the fan leads hard to find? As you can see, I haven't thought this out. Glad you did. Let me know, Earl
