Burning oil
Discussion in 'Technical' started by Comet-73, Feb 10, 2004.
  1. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    My 302 mav is burning oil, i know theres no quick fix but i just like to know if it would be my rings or my vavles if i put a peice of carb board behind the muffler and let it sit for idling for like 5 min there is a little bit of oil on the cardboard.. i was just wondering if that would be vavles or rings or how do i check
  2. 71gold
    could it be carbon being washed out with water? ...frank...
  3. mavman
    mavman Member
    Arkansas
    The easy way is to use a leakdown tester. Or, you can use a compression guage. Do a compression test on one cylinder and record the reading. Remove the hose from the cylinder and put a little bit of oil down in the cylinder, then do another test. If the reading increases a lot, that's a sure sign of worn rings.
    Dont forget PCV system...sometimes the little pcv valve can become stuck and allow oil to be pulled into the intake manifold. Also could be a leaky intake manifold gasket pulling oil into the intake runners around the leaky gasket.
    Those are just a few causes of oil usage/smoking. I'd try the simple stuff first, and I'm sure others will add more tips/suggestions. Good luck
  4. Comet-73
    Comet-73 Member
    Could some one post a pic of the PCV system, I have heard of it but im not sure what people are talking about. Im pretty sure its not the rings
    I was not doing this until recently when i rebuilt the carb it started to happen
  5. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    how many miles before you add a quart? if it happened after you did the carb, maybe it isn't oil burning at all. just a real rich gas mixture?
  6. Comet-73
    Comet-73 Member
    I exhuast did smell a little rich and, also i was toping off my oil and noticed that if i pulled that little hose from the carb of the valve cover alot less oil came out and when i put it back on oil came out
  7. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    Many forget about the valve guide seals. When they get brittle, they can let oil past into the cylinders. I believe that may be the problem I'm having with oil fouling with my 4 door 250.
